TNGW1500SE
Jun 11, 2016Explorer
I built a plywood platform over the bottom drawer in my Sunova that the fridge sits on and cut the cabinets so it fit. It you look at the big box DIY stores, you may be able to find some finished trim that matches your woodwork. Look in with the paneling, molding and flooring. Sounds like if it's that close you may ave an easy install. We went with a bigger fridge that the Nevercold brand that was factory installed. You also need to think about what you're going to do with the old fridge vents. They may be open to the outside with no screening since they are vented due to burning propane. I replaced my side vent with one of these:
Google "boat hatch"
and then removed to roof vent and sealed it with:
I made sure I had airflow around the new fridge by venting it above and below to the inside of the RV. You're going to have some 12 volt wiring that you need to "cap off" so there's no short later down the road. You may think of some use for it. The only drawback is you will be able to keep ice cream and it will make you fat.
Google "boat hatch"
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: Jun 07, 2026
