pianotuna
May 04, 2018Nomad III
Hi,
While the connections to the buss are equal length, the length of the buss to the charger from battery #4 is MUCH greater than from battery #1. That leaves it unbalanced.
Stack the cables (two under the bar and two above the bar) on a single connector. Loads can go anywhere on the buss.
ependydad wrote:pianotuna wrote:
Your bank is not balanced.
Have a look here:
http://www.smartgauge.co.uk/batt_con.html
I use method #3
Don, thanks for sharing that link. I had seen it before but couldn't find it when I went to make this diagram. That said, I tried to reproduce method #3 from memory and looking again, seems like I did.
Would you mind taking a closer look? Is there something specific in my diagram that you think I've missed?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
