ependydad
May 04, 2018Explorer
pianotuna wrote:
Hi,
While the connections to the buss are equal length, the length of the buss to the charger from battery #4 is MUCH greater than from battery #1. That leaves it unbalanced.
Stack the cables (two under the bar and two above the bar) on a single connector. Loads can go anywhere on the buss.
I see. I think that was more an issue of the diagram than what it would actually be in reality, but still good to be mindful of.
Do you have any recommendations for bussbars to buy?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
