westend
May 27, 2018Explorer
ependydad wrote:I hope you don't mind but I see a few things that could be changed--I'd suggest to locate your shunt between (-) bus bar and frame. I'd also move the disconnect to the (+) polarity but that's just me.
Ok, I've revised the diagram with a couple of updates:
- I noticed my charger was bypassing the battery disconnect and worse was also bypassing the shunt so it wouldn't be counted.
- I tried to add clarity to the 15amp transfer switches
- I tried moving the charging points so they would more equally balance the batteries
Click for full-size
Between the devices and 12V supply there should be circuit protection.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
