westend
Jun 01, 2018Explorer
ependydad wrote:(-) or (+) location for disconnect: Best practices.westend wrote:
I'd also move the disconnect to the (+) polarity but that's just me.
Between the devices and 12V supply there should be circuit protection.
Why the (+) side vs (-) side?
What type of circuit protection are you thinking? That's why I had the fuse block there.
The circuit protection for each device should be between the power supply (bus bar on your diagram) and the device. After looking at your diagram again, I see that the fuse block is between the bus and the devices with a circuit breaker protecting the inverter. You're right on, excuse me.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
