Wrace
Oct 02, 2014Explorer
Thanks for posting, Wes.
I should probably start researching a re-roof option for my 17 year old epdm roof. I didn't know there was an epdm coating available, I'll have to look that up.
Did you remove the side gutters/molding or just paint down to the top edge of the gutter?
What type of material will be used for the white top-coat?
You mentioned some small leaks, do you know the origin of these leaks?
You mentioned other research resources such as another forum? Is there other discussion forums that cater to do-it-yourself RV'ers?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
