99_Starcraft
Oct 02, 2014Explorer
Wrace wrote:
Did you remove the side gutters/molding or just paint down to the top edge of the gutter?
Just painted to the top pretty much.
Wrace wrote:
What type of material will be used for the white top-coat?
Rustoleum Profressional Gloss White Protective Enamel
Wrace wrote:
You mentioned some small leaks, do you know the origin of these leaks?
The major portion of the leak was covered from the side. I fixed that a while ago and am not sure where the little bit that remained was coming from. I'm pretty sure that it was from the original seam between the rubber roof and aluminum siding though.
Wrace wrote:
You mentioned other research resources such as another forum? Is there other discussion forums that cater to do-it-yourself RV'ers?
It's just another forum similar to rv.net. There may be something more specifically geared like that but I don't know about any.
westend, I know they are and I thought about using one. Part of the point in the bed-liner though was it's cheaper than the roof coating. If I went with the white (or any other color) liner it would have cost 2 or more times what it did per gallon. For the three gallons of bed coating and one gallon of paint I'm still in about $133 total for the coating.
Camp, Forrest, Camp!, brave enough or stupid enough? LOL
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
