rbrand's avatar
rbrand
Rube Goldberg move over.
I wanted to install a Tornado washer into my black tank but the only place it could go, did not have enough space between the frame and the tank for the drill & hole saw. But there was a small opening above the frame. By cannibalizing several tools, I made this thing and it worked awkward but functional.
I used a Dremel for the screw holes.
  • Trackrig wrote:
    That's a nice home-made tool. I have one sort of similar that my Dad built a long time ago. When I needed to retrofit the current house with in floor radiant heating, I had to drill over a hundred 2-1/2" holes in the floor joists. Then it was time for something bigger.
    It has a 1/2" chuck and I haven't found anything it can't power through. You need that long handle to control it due to the leverage when it a big bit digs into a knot or something.
    Bill
    That is what I needed.
  • That's a nice home-made tool. I have one sort of similar that my Dad built a long time ago. When I needed to retrofit the current house with in floor radiant heating, I had to drill over a hundred 2-1/2" holes in the floor joists. Then it was time for something bigger.
    It has a 1/2" chuck and I haven't found anything it can't power through. You need that long handle to control it due to the leverage when a big bit digs into a knot or something.
    Bill
  • profdant139 wrote:
    Brilliant! Are you able to get your hand down near the hole saw to hold it in place?
    Is there a reduction gear in that right-angle gearbox?
    The right angle drive has a 2:1 reduction. If you reverse it it is a 2:1 increase.
  • Bill.Satellite wrote:
    Good luck with that Tornado! I replaced mine twice in about 2 years and then gave up on trying to keep it working.
    First Tornado I purchased was busted right out of the package, returned it and got another, it lasted a few months then broke as well. No wonder, it's all plastic ... and IMO a waste of $$. :M
  • drsteve wrote:
    If that would take the 3/8 shaft of the hole saw I would have used it.
  • Good luck with that Tornado! I replaced mine twice in about 2 years and then gave up on trying to keep it working. I went back to a No-Fuss Flush and have been happy for years.
  • It got the job done. Who cares if it looks like a Medieval Torture Device. :B
  • Brilliant! Are you able to get your hand down near the hole saw to hold it in place?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
