DrewE
Dec 30, 2018Explorer III
enblethen wrote:
If you can get to where your current cord enters, you could splice in to it there or run to the 120 volt power distribution center.
Don't do this as described, though. You need to have some sort of a positive transfer switching system, not a splice between two electrical inputs, as the splice would make the inlet cord's plug hot when using the generator and permit you to connect line power to the generator with predictably very bad results.
An automatic transfer switch is one option. A manual switch may be another. A cord and plug setup is a third.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
