ajk170's avatar
ajk170
RV Awning clearances for second awning install
Hello! I am hoping somebody can help shed light on a 2nd patio awning install we would like to do on our 2015 Keystone Outback 316RL. Specifically, we want to add a second patio awning on the slide. But I'm not sure what type of clearances we need (i.e. from windows, top of the slide, overhang of awning on the sides, etc.) We do have a rail above the slide that a slide topper could attach too but we haven't done that. My initial though is, "Why couldn't we use that rail to attach a patio awning to it and as the slide extends out it naturally unwinds the awning (of course we would have to unlock the awning before extending) and then once the slide is fully extended, we just finish pulling the awning out the rest of the way until it too is fully extended. Or would I have to install a rail kit on the slide itself?
  • 4x4van's avatar
    4x4van
    Explorer III
    I doubt that "low overhead" would be an issue, as long as your awning includes the typical adjustable length legs. As for rubbing on the top of the slideout; that may indeed be an issue depending on how much lower the slideout is vs the awning rail on the main part of the MH. However, some edge trim, maybe like that used on car doors, along the top edge of the slide would likely take care of that.
  • 4x4van- thanks for the response and letting me know that you’ve seen what I’m talkkng about. One of my concerns is the height that the awning would be at since it would be about 12” lower than the main patio awning- would it create a “low overhead problem”. The other concern is, would the awning rub against the slide’s edge or would it have enough height to clear the edge of the slide as it extends beyond the slide? I figure it would extend out in and angle and not straight out from the slide. I wonder as it extends out on an angle, would it rub and potentially create holes?
  • 4x4van's avatar
    4x4van
    Explorer III
    I've actually seen that exact setup; not sure if the awning used was specifiaclly designed for double duty or not. You would have to make sure that the roller is above the top of the slideout, and (as you say) the awning is unlocked BEFORE extending the slideout.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
