crazyro
Jun 04, 2018Explorer
Dutch_12078 wrote:crazyro wrote:Dutch_12078 wrote:
How do you open the sliding panel?
I don't plan to - that's why I drilled through it. If it ever becomes an issue, I will redo the wire and bend it around the slider.
As the others have said, it will become an issue when you try to open the outer door from inside.
Yes, unfortunately I had the main door open while working on this and never had a reason to attempt to let myself out. It should be an easy fix though - at the expense of another wire hanger. Hehe.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
