crazyro's avatar
crazyro
Screen door handle and wire hanger opener
Picked up a brand new, unopened, screen door handle at a yard sale this morning ($1) and installed it. I've been considering getting one. Score!
Also hated having to continually slide the screen door trap door to open it and saw the wire hanger mod so I went for it. A small wooden dowel and leftover rubber seal, and presto! This will make things much easier.
  • I made this, it works great!! Just a piece of wire, pull on it on the inside and the door opens easily.
  • downtheroad wrote:
    We have this:......Screen Door Slider....
    X2. Works great. I did mine several years ago before the kit came out and discovered that I could not use a flat piece of plastic and get the clearance I needed. Had to install the knob on my slider which is not flat.
  • Dutch_12078 wrote:
    How do you open the sliding panel?
    I don't plan to - that's why I drilled through it. If it ever becomes an issue, I will redo the wire and bend it around the slider.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Mar 10, 2025
