lawrosa
Feb 16, 2018Explorer
CA Traveler wrote:
Suggest you read up on unbalanced wiring and understand why those long wires from the truck have voltage drop especially at higher loads and charging and is part of the reason for your results. Battery amps will not split evenly (with 3 equivalent batteries) due to your unbalanced battery wiring.lawrosa wrote:This has the real potential to wake up with 3 dead batteries and the truck won't start.
My set up is only for when parked at camp. Truck will be plugged in during PM hours.
A quick start of truck for 30 minutes or so to get some amps in the batts in AM and let solar continue from there.
Batt on truck is aux battery with isolator. Does not affect start batt.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
