DFord
Feb 29, 2020Explorer
For those that use cables to secure your "stuff" to prevent theft:
You can buy this cable cutter at HF for $20 to silently defeat the thickest cable.
If on the other hand, if you use heavy chain, you take your pick of bolt cutters that will pop a chain with almost no noise:
https://www.harborfreight.com/search?q=bolt%20cutter
If all else fails, Dremel makes a battery powered tool with a cutoff wheel attachment that will slice through just about anything including hardened locks. It does make a little noise though.
The point I'm making is that nothing is safe anymore if the theft shows up prepared. Bolt those things down - you can't rely on chains and cables anymore.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
