valhalla360
Mar 01, 2020Navigator
agesilaus wrote:
2) I would get nervous with a 100lb generator plus another 100lb of gas...that's a lot of weight and the back of a trailer can move around quite a bit on rough roads.
The gen weighs 80 pounds and the gas can 40, so 120 pounds not 200. And what are those carriers designed to carry, feather pillows? I usually see big ice chests full of water and cans.
OP said 95lb generator and a couple cans of gas...that can get up pretty close to 200lb.
I see people doing scary stuff too...doesn't mean I would recommend it. If things shift on the rack, that's a lot of torsion on the 2" receiver and some have a pretty sloppy fit in the receiver, so I've seen them flopping around. A bad weld or using the paper thin rear bumper for support and after a few thousand miles on rough roads (OP is heading to alaska), and a failure is a real possibility if not a solid design.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
