CJM1973's avatar
CJM1973
Securing Generator To A Cargo Carrier On A Receiver Hitch
Looking for ideas on the best way to secure a 3700 watt inverter generator to a rear cargo carrier attached to a trailer's frame mounted reciever hitch. Genny weighs about 95 lbs. I've seen a couple of products online, one being a locking tray that attaches to a reciever hitch:
Generator tray for receiver hitch
As I would like to use my larger 60x24" cargo carrier (to carry additional fuel), what have RV owners done to fabricate something like this with an existing carrier? Pics would be helpful.
I thought about constructing a 5-sided expanded metal box to slip over the generator, bolting it down to the carrier and punching out 2 windows for front panel and fill cap access. I could then slip over a waterproof cover and it would be hidden from view.
The plan is to make power accessibility extremely easy for an up coming 2 month alaskan adventure. As we'll be moving pretty frequently, it would be nice to be able to remove the cover, connect the 30 amp trailer plug, and use the wireless remote to start/stop the genny without ever having to move it.
Again, any pics on how to best secure a generator tona cargo carrier are appreciated.
  • Thanks for sharing. I do have the option of installing a receiver hitch on the front of my tow vehicle, a 1 ton GMC Savana 3500 extended passenger van. But, I'm not keen on keeping a covered generator and gas can on the cargo carrier in plane view.
    I would like to see how you fabricated the mounts to your cargo carrier. Do you have a pic of it? Just looking for ideas.
    I thought about fabricating some metal strapping up and over the top of the generator and bolting the ends to the cargo carrier's frame. That would take care of both the mounting issue and security issue. I could then apply a metal cage over top and cover with an oversized cover.
  • 2) I would get nervous with a 100lb generator plus another 100lb of gas...that's a lot of weight and the back of a trailer can move around quite a bit on rough roads.
    The gen weighs 80 pounds and the gas can 40, so 120 pounds not 200. And what are those carriers designed to carry, feather pillows? I usually see big ice chests full of water and cans.
    OP said 95lb generator and a couple cans of gas...that can get up pretty close to 200lb.
    I see people doing scary stuff too...doesn't mean I would recommend it. If things shift on the rack, that's a lot of torsion on the 2" receiver and some have a pretty sloppy fit in the receiver, so I've seen them flopping around. A bad weld or using the paper thin rear bumper for support and after a few thousand miles on rough roads (OP is heading to alaska), and a failure is a real possibility if not a solid design.
    The trailers receiver hitch is not oem. It was fabricated by a metal shop that specilizes in hitches. It was secured and reinforced to the frame rails by a professional fabricator/welder. It looks better than any class three hitch I've seen on most motor vehicles. I've seen some sketchy bumper mounted receiver hitches that are about as polar opposite as my frame mounted trailer hitch. So, quality is a mute point.
    It's a 95 lb generator and two 2.5 gallon cans of fuel (30 lbs). The cargo carrier is approx 55 lbs. Would be well under 200 lbs.
    That sounds much more viable.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 13, 2025
