IAMICHABOD
Nov 13, 2017Explorer III
When I wanted to do the same thing I had a light that I would get the power from and had a hollow wall,I unscrewed the light and thru the hole in the wall where the wires came up I tied a washer on a string and fed it thru and took a strong magnet and pulled it along until it reached the hole where I wanted the put the USB port.
Pulled the string attached to the wires then installed the USB port,all wires inside the wall.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
