Dutch_12078
Oct 02, 2013Explorer III
I installed my SeeLevel II system in 2008, and couldn't be happier with it. The percentage readings are much more accurate than the standard "Empty,1/3,2/3,Full" systems. The installation is comparatively easy if you have reasonable access to your tank walls and the existing sensor wiring.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
