ronfisherman
Oct 02, 2013Moderator
There are a couple of notes that I should add.
1. Wish I had installed 709 PH SeeLevel system. After I installed the 709. I found that circuit board on original monitor is all in one. Not possible to separate.
2. I should have mounted the sensors on side of black and gray tanks to more accurate reading of full.
Beyond that I am very happy with the install.
Here are some pictures.
Fresh Water Tank.
Gray and Black tanks.
Fresh Water Tank.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
