JimM68
Jul 14, 2014Explorer
Wow, am I the only one to have trouble?
Mine worked right for about a year, then started giving flaky readings.
The 2 panels (one inside, 1 in the wetbay) do not read the same. Black never reads less than 35% both gray and black seem to read something different everytime I press the button. Both read 100% LONG before the tanks are full (I installed them near the top of course...)
I used the original wiring...
I soldered and heatshrinked all the splices.
It initially went crazy after I sprayed down the wetbay with 409 and hosed it out to clean it.
Seelevel said the sensors can't take that, so I paid for replacements (they refused to warrantee anything) but the new sensors made bo difference at all.
I've removed both panels (one at a time...lol) but no change.
I've used a few different tank cleaners, including using the GEO method for a while.
The Techma toilet sensor has always worked perfectly, and still does, but this is just a green, goes yellow at 50% ish, and when it goes red the toilet won't flush.
I'd really like this setup to work good again.
And I sure wish there was easier access in the Monaco's wet bay.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
