redkoat64
Mar 09, 2013Explorer
Hello,@Ductape Dave,
You might try arranging the tiles starting from the "open" edge and lay the tiles in succession until you get to your endpoint. Each sheet has a straight edge and a staggered edge. So draw a level line on your wall and lay the straight edge of the tile sheet against your line. It won't look like its hanging out there in space. It also helps to dry fit the tile sheets, just to see how they look. Painter's tape will hold them up without damaging them. There are also great bathroom tiling instructions on www.smarttiles.com Good Luck!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
