Bob_Vaughn
Jul 28, 2013Explorer
We went to HD this morning and looked and looked could not find the 9 sheets that another HD said they had. Finally an associate found where they were as they were not with the other tiles... I bought way too many because I forgot to measure before I went there so I will be returning a lot of sheets....This HD had lots of styles to chose from. My question for those that have installed them is can they be cut with a paper cutter? at least the long straight cuts? at 10 dollars a sheet I do not want to be making a mess with the cutting. Also in the corners there is a corner piece and was wondering if I have to remove that prior to installing the tiles?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
