- popeyemthExplorerGot it.
Thanks again,
Mike - Jayco25EExplorer
popeyemth wrote:
That is a tub and not a shower pan, correct?
Yes mine is a tub. I would think it would work for a pan as well just would need the full lenght of the curtain. - popeyemthExplorerThat is a tub and not a shower pan, correct?
- popeyemthExplorerThanks for the info
That improvement is on the short list - Jayco25EExplorer
popeyemth wrote:
The original curain was fastened to the ceiling on a rail so it could not be used. I just bought a standard curtain from Walmart and had to shorten it by about 5" and cut about 16" off the lenght as to not have to much curtain bunched up that was not needed.
Did you need a longer curtain ? - Jayco25EExplorer
popeyemth wrote:
So it swings 180 degrees- from inside the shower to the outside ?
Thanks,Mike
Yes gives you more room in the shower when needed. And more space outside the shower when not using. - popeyemthExplorerDid you need a longer curtain ?
- popeyemthExplorerSo it swings 180 degrees- from inside the shower to the outside ?
Thanks,Mike - Jayco25EExplorerHere is a picture of the curtian out.
- Ron3rdExplorer IIIOne of the best mods I ever made on our old trailer. Loved it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Jan 01, 2026
