Ductape_Dave's avatar
Ductape_Dave
Silicone or 3M 5200 caulk for Wood to Aluminum Roof?
I have a stationary trailer at a site and I plan on adding a room. I need to add a 2x4 ledger flat on the aluminum roof of my old '78 Prowler. My question is which one would be better as an adhesive, silicone or 3M 5200 caulk?
Thanks in advance,
Dave
  • DrewE's avatar
    DrewE
    Explorer III
    I would use some sort of a mechanical fastener, rather than relying on adhesive to hold the ledger in place. I'd also prefer it to have a bit of a standoff above the roof so that it's not going to sit in water for long periods when it rains. (Pressure treated wood would be a bit longer lived in such a situation, but modern pressure treatment chemicals are quite corrosive to aluminum and will cause holes in the roof sooner or later--quite possibly sooner, as in a year or two or three.)
    One way to do both of these is to screw an aluminum angle to the roof (sealing the screws etc. with some appropriate caulking material, Dicor or ProFlex or OSI Quad for instance), and then attach the 2x4 to the vertical part of the angle with lag bolts or similar.
  • Silicon is the worst thing to use.
    As for 3M 5200 it's great stuff just remember it's listed as permenit
    as in once you lock parts together don't plan on ever taking them apart.
    I'm told there is a 3M 4200 which is not as aggressive as 5200.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,411 PostsLatest Activity: Jun 27, 2026
