whiteysax's avatar
whiteysax
Skirting fifth wheel
As I settle into my first winter as a full timer and learning as I go, I'm planning to skirt my 5er as I've deduced the major cause of chilly drafts is coming from the floors of my slides (around the couches in the front living room, around the bed in the bedroom and under the table in the kitchen).
Obviously, I'd like to avoid the thousands of dollars involved with professional custom fitting. I happened across EZ Snap skirting kits, but I'm not too keen on screwing studs into the body of my home and it would appear I'd still be spending $1500-2000 to wrap fully around my 40-ft rig AND 5 slides. I'd like to skirt it with a fabric material as opposed to insulated boards for storage reasons. I'm just not sure where I'd store boards should I need to.
I'm toying with the idea of custom fitting a skirt on my own using adhesive snaps. Has anyone had any success in outfitting your rig with a homemade skirt? Suggestions on skirting material?
  • Here is what I did,
    for my 28' Desert Fox TH RV that we use mostly in the colder weather
    Works like a champ and down to -20* this year.
    See info Here:
    http://s1220.photobucket.com/user/Nvreloader/slideshow/
    Tia,
    Don
  • Almot's avatar
    Almot
    Explorer III
    There is no way to fasten it reliably to the rig without either building a frame underneath, or driving screws into the rig. Friction-fit foam will fly away in heavy winds. Suction cups will come off with time, and/or rubber will become brittle. Duct tape will turn into dust after one hot summer (and what will remain, will be a pain to clean off the rig).
    If this is a permanent site - build a frame. Whatever you put on it, is not critical. Can be a block foam, can be plywood, can be discarded corrugated metal or fiberglass, pieces of siding, truck tarp - whatever you can get for cheap or free. Dissimilar pieces can be painted. Under the front you can put a piece of plywood on two hinges to make a shed for items not too valuable.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 13, 2025
