Sky Deck wrote:
westend wrote:
IMO, these SIP panels are great in a wall situation where compression of the foam isn't an issue but place them in a floor where support is barely adequate or the wood layer could have little tension, and a problem is bound to happen.
I hope I'm not scaring you about your floor. If I owned the Sky Deck, I'd keep what I had for the floor and not give it a second thought, other than to have adequate joists, especially in traffic areas.
No worries. As I said, I'm very interested in SIP panel construction, so I think it's pretty cool that my new home uses SIPs and I might just get to work with them. But I don't know anyone who has a lot of experience building with them. The bottom line, of course, is that all the research in the world isn't as valuable as inspecting the real thing, 10 years later. Now I need to find out where to get panels to replace this one, before I go tearing it out. I am optimistic that they've only gotten better over the past decade.
By the way, check this out: http://www.singloghomes.com
My take is that any part of smaller conventional residential and commercial building construction is going to migrate towards anything that can be manufactured and built in a plant, off site.
I'm up here in a suburb of Hudson's Bay (Minnesota, actually :B), we go to great pains about insulation. If the SIP panel can handle the weather, it will be used. Manufactured homes already exist that use them, not so much in typical mini-mansions that folks crave.
I read some at the Sing site and it's an interesting concept, especially the efficient log use as it uses timber that would otherwise be graded for another use, probably more wasteful.
If you need to use a piece of SIP and can't find an off-the shelf one, you could DIY with a big plastic bag and a shop vac.
