outnabout's avatar
outnabout
Slide out awning installation
I have a Montana 5er that has the refer in the middle slide. The vent is in the way of a normal install of slide awning brackets. I see they install the brackets on the frame or the flange of the slide but don't know what screws or bolts that are used. Anyone done this or has one, let me know. Thanks
  • I just did the install tonight, I to have the fridge issue. I made brackets that screwed above and on side if the fridge vent, It screws into the black 4 in flange surrounding the fiberglass. I can send you a pic later. the awning I used is the standard A&E. I think the homemade bracket is stronger than through the fiberglass as per normal install. The flange is aluminum and then there is an aluminum frame behind that, I wad told by dealers it couldn't be done, and carefree of Colorado say they have an awning that might work but at more than 2x cost of the A&E
  • I am not sure this will help you but it does show the install of a topper. If you can find the topper install instructions it might answer your question.
    Install Topper
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Jan 01, 2026
