wowens79
Jun 24, 2021Explorer III
kfp673 wrote:
Just went through this. Found one on Amazon being advertised as RV slide hose which basically meant it's the more flexible rubber type hose. Went 1' longer than factory zip timing to the factory spring the way it came but with more slack, but realized no matter what I did it was going to bind. Had a very specific plan to simply hold the hose away from the pinch point when putting in the kitchen slide but then last week my wife put the slide in without me and forgot and now the new hose is kinked again. Please post if you find anything that works.
do you have room you could put a pulley for it to go around that might prevent the kink??
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
