stevenal's avatar
stevenal
Nomad III
Dec 27, 2025
Slow water/noisy pump
The water seemed really slow at the kitchen sink during our last overnight, and the pump sound was clunky. Decided to tackle it yesterday. I had never noticed the strainer on the pump inlet before, and decided to start there. With the winterizing hose plugged, I moved the valve to the winterizing position so that I wouldn't need to drain the tank; then unscrewed the strainer. There was a bit of debris, mostly plastic that I figure must have been from the tank assembly in '18. I cleaned and re-assembled the strainer and ... no joy. Next I decided to look at voltage. With no clear way to check at the pump, I checked at the fuse. Looked good. I thought of checking voltage further at the switch, but decided to look at the kitchen sink aerator first. Again I found a bit of stuff, which didn't seem enough to make a difference. It did in fact make a big difference. The flow is much better and the pump runs smoothly. Just thought I'd mention this little journey in case someone else has a similar issue. Happy New Year.
  • About every three months I have to take off our aerators and clean them out. We get some debris mostly some plastics that are left over from manufacturing or deterioration of our outdoor inlet hose. Glad you found the problem and the solution.
  • yup thoes sink aerator can make a huge difference, I clean mine out every spring.
  • I clean the strainer on the pump about every 6 mos. Amazing how much sediment gets in there. Doesn't take much to decrease flow.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
