pianotuna
Aug 24, 2013Nomad III
Hi barntt,
No, so long as the wire is able to legally carry the number of amps and is using a PWM controller voltage drop is a NON factor. That's just one of the mistakes at the page you suggested folks read.
If it is MPPT then wire size is important and should be as big as can be accommodated with the shortest possible run.
Large wire and short runs are an advantage from the controller to the battery bank.
The trimetric doesn't measure as well as the Victron gauge, and is more costly. I don't use an amp-hour counter myself.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
