Almot
Aug 28, 2013Explorer III
oakmandan wrote:
I am interested in using a basic solar panel with my camper to charge one or two 12V batteries. I would want to be able to run the water pump, a light or two and a 12V fan. Any suggestions of how to and what equipment I would need ?
Will see if my brains aren't sleeping yet...
Water pump: 10A? @20 minutes a day = 3 AH
Light: LED? You should go LED if you go solar. One light 4 hours = 2 AH
12V fan at medium speed 2A, 12 hours = 24 AH.
As you can see, a lot depends on how often you run the fan.
No radio? No 12V circuits in propane fridge? I've seen some minimalists, but wouldn't it be more sensible to use a hand pump on a 5 gallon jar in this case, rather than running a 12V pump, and save some AH for a 2nd light or a radio? :)
OK, total 29 AH = 100W-120W flat panel approximately. Make it 140W to compensate for battery losses. With 10A MPPT controller and #12 wire. If you are willing to mess with titled panel, 120W should do.
Like somebody noted, on a weekend trip you can just forget about solar and come back with 50% discharged battery after 2 days.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
