MrWizard
Aug 29, 2016Moderator
Rbertalotto wrote:
I already have 280w of solar and two Group 31 12v AGM batteries. I'm just looking for a way to take more load off the house system as I can't add any more batteries or another 140w panel.
I usually never use the fan at night. Only doring the day to moderate the temperature.
Just thinking a little outside the box....
the case of a 'fix looking for a problem'
does Not the 280w keep up with your needs and the fans
are the batteries discharging during the day while using the fans
do you NEED more solar because the batteries are not fully charging
or is this just a case of 'tinkering gone wild'
your looking for something to do
in which case i suggest a NEW battery monitoring system
or an 120vac power monitor system
or An Energy Management System
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
