Portable_Paradi's avatar
Jun 13, 2015
Soft Flooring in Gulfstream Super C
Anyone have any experience with repair of a soft flooring in Gulfstream Endura 6430 Super C? I have a small soft spot outside the bathroom.
I get the general gist of the repair but am looking for advise from someone who has done the job. Where are the supports located in this coach? Any type of sealants, glues materials used for a better quality repair.
Thanks Much.
Portable Paradise (down for the moment)
  • Good morning. I have a 6340 with the same soft spot. I know it has been a while that you posted this question. I saw the one reply but am interested what you found once you started the work. Thanks for you time. I hope to hear from you. Doug
  • Supports for the flooring are built up from frame. The used 1" square. When construction was started. Frame for flooring and compartments were welded in place. Then flooring was installed. Next internal walls and cabinets were installed. Then they install the outer walls. Last was the roof.
    If the soft spot is under a wall. Then it complicates the repair. Hopefully yours is not across rooms.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,411 PostsLatest Activity: Jun 13, 2026
