DrewE
Oct 03, 2016Explorer III
Probably easier and cheaper, if less elegant, is to run 500' of low-voltage landscape wire from your house down to your camera location. Use a 12V or so power supply at the house, and have a 5V regulator or DC-DC converter for the camera, so as to accommodate voltage/power loss in the wire. (This should be adequate for even 500 feet of 16 gauge wire with a load requiring 1A, which would have a total voltage drop of about 4V in this situation.)
A 500' roll of 16/2 landscape wire is less than $100 from Home Depot. If installed carefully in proper weather-sealed enclosures, this should operate without difficulty for a long time with basically no maintenance.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
