I did a weekend of boon docking and found that daily I had to run the genny. I am interested in a simple solar panel set up, portable enough that my wife can set it up, to boost the battery and allevi...
It use to be that the portables from the fancy outfits were so expensive that you could build your own cheaper. Now it's hard to beat the ones from solarblvd, windynation, eco-worthy, renogy and others.I saw a you tube of someone setting one up and it's pretty easy.
I make my own portables out of the larger higher voltage panels. They are 39x65 and weigh close to 50 pounds, One panel, one run of cables to the controller, around $400 for 16a+ of charging tracking the sun all day.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
