2manytoyz
May 05, 2015Explorer II
scrubjaysnest wrote:
Per NEC for 30 amps of solar you will need a 45 amp controller; NEC derates them to about 36 amps. Our worst case boondocking usage takes the batteries to 47% state of charge in one day. That is ~662 WH. We are very conservative and normal usage is ~189 WH. A quick and dirty rule of thumb 100 watts of solar per 100AH of battery, but the reality is more complicated.
MorningStar Corp says no need to derate their charge controllers. They will shutdown if too much current, heat, low voltage, etc. They also already factor in a fudge factor.
More details here: http://www.solardirect.com/pv/controllers/prostar.htm
I'm using two of their Prostar 30M controllers, and a Morningstar Sunsaver 10L. Excellent products.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
