Almot
May 06, 2015Explorer III
skripo wrote:
I got the connection sequence but how can you monitor DC load power consumption if it is not running "through" the controller?
By installing a battery monitor by Victron, Xantrex, Bogart.
As best I can understand now, I connect the the controller as follows:
Battery goes to Controller Battery
Yes.
DC panel goes to Controller Load
No. Connect loads to battery. Don't use Loads terminal and LVD feature
Panels go to Controller in
Yes
And finally, the converter is direct connect to battery.
Yes.
The amperage worry comes in if I need to run 40 AMPS through it.
Sorry. You need 40 A through what?
Here is a PROPER diagram to connect solar system with inverter and loads - it shows 2 controllers, ignore the 2nd one. Page 19.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
