pianotuna
May 06, 2015Nomad III
skripo,
You need to use fuses. #10 wire for the five foot run and #8 for the charge controller to the battery. Larger will result in lower voltage drop.
There is NO advantage to using the load outputs on the charge controller. If you ever exceed 20 amps it will burn out the controller. There is already wire from the battery bank to the DC distribution panel. There is already wire from the 55 amp converter (yes this is RV speak, the really really name is inverter from 120 vac to xx.x volts dc) to the battery bank.
How many watts of panels do you plan on installing?
How many amp-hours is the battery bank?
Are you a weekender or a full time RV person?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
