westend
May 08, 2015Explorer
Any PWM charger will handle nominal 24V modules (as long as the input rating is not exceeded). A user will be giving up some power, though. IIRC, my MX Solar module's rated output is 8 amps at 36 V. I can get 15 amps if conditions are right. That is a fairly large gain in power harvested using MPPT.
I shouldn't have recommended the Bogart controller. Had a senior moment and forgot that the modules in question, here, are nominal 24 V. The Tracer will be a good fit with those modules.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
