skripo
May 08, 2015Explorer
smkettner wrote:skripo wrote:Morningstar SunSaver MPPT will work perfect with one or two of these panels.
My 135 watt panel is 24 Volts and I may add another. I already own a new Net Solar 30 amp that was for another project.
I also wanted the ability to program my own charge profile because my AGM battery is slightly different than the stock ones you usually see.
Programming can even self adjust absorption time for storage vs in-use.
http://www.morningstarcorp.com/products/sunsaver-mppt/
https://www.solarblvd.com/product_info.php?cPath=6_46_228&products_id=2000
I think you need to recheck your numbers. This model you referenced only handles 200 watts with a 12v battery so it's only good enough for one 135 watt 24v panel.
For the same price, I got a 40 Amp controller AND a remote display. I fail to see how this is a better buy.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
