westend
May 10, 2015Explorer
skripo wrote:
I ordered 50 feet of 10 AWG 1000V cable, crimpers, MC4 wrenches, and 5 MC4 connectors.
Is there any reason NOT to solder the MC4 pins to wire? I am a soldering maniac and always want the best connection.
Can I use the same cable to go from charge controller to battery? Run is about 3 feet.
Thanks.
Reason not to solder: connection system is not engineered for solder or excessive heat. You may melt a connector or set up a failure point for the future. Use crimper, save iron for other duty.
I would use the largest possible cable (that fits controller) for the charge controller to battery connection. My reasons are above.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
