skripo's avatar
skripo
Solar charge controller selection help needed
I am looking to put in a solar system that will produce about 30 amps per day. I choose a semi-flexible 135 watt panel made by Sunpower which meets my capacity needs.
My only problem is choosing the charge controller. My original choice was a 20 AMP Suntracer MPPT (yes it is a REAL MPPT) with the remote panel.
My only issue is that I want to use the see consumption and use the low voltage battery disconnect, unfortunately my converter is 55 AMPs. If I want a 55 AMP or more charge controller the cost goes up obscenely.
Realistically, what is the maximum draw I can see from 12V lights, heater fan, and other 12V loads. I know it is hard to estimate but what is typical?
Also, does the converter ever supply 55 amps for battery charging?
Thank you.
  • Thank you for all the replies.
    Pianotuna: I think so. I have this battery and it is 50% after 2 days of use.
    Westend: Thank you for the calculator. Some converters have a consumption meter and an LVD function that disconnects the battery when it drops below a certain voltage.
    Unfortunately the charge controller needs to sit between the battery and the load to do this and has to be sized to the load amperage.
    I am assuming that worst case scenario would be 55 amps because that is my panels rated amperage.
    30AH/day would be typical with one 135W module, maybe a bit more if the sun is good.
    I know squat about that controller but is sems to have a rating large enough to handle a single 135W module.
    Don't understand the thoughts, here. Please try again.
    Download this spreadsheet calculator and add up your total:Quartzfest calculator
    Yes, it's possible that a 55 amp converter delivers 55 amps at the output terminals. You will need adequate cable, a battery that will accept the amps, and a circuit breaker between battery and converter greater than 55 amps (some are only 30 amps)
    Thank you.
    Hope it helps
  • Per NEC for 30 amps of solar you will need a 45 amp controller; NEC derates them to about 36 amps. Our worst case boondocking usage takes the batteries to 47% state of charge in one day. That is ~662 WH. We are very conservative and normal usage is ~189 WH. A quick and dirty rule of thumb 100 watts of solar per 100AH of battery, but the reality is more complicated.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,405 PostsLatest Activity: Apr 21, 2026
