skripo's avatar
skripo
Solar charge controller selection help needed
I am looking to put in a solar system that will produce about 30 amps per day. I choose a semi-flexible 135 watt panel made by Sunpower which meets my capacity needs.
My only problem is choosing the charge controller. My original choice was a 20 AMP Suntracer MPPT (yes it is a REAL MPPT) with the remote panel.
My only issue is that I want to use the see consumption and use the low voltage battery disconnect, unfortunately my converter is 55 AMPs. If I want a 55 AMP or more charge controller the cost goes up obscenely.
Realistically, what is the maximum draw I can see from 12V lights, heater fan, and other 12V loads. I know it is hard to estimate but what is typical?
Also, does the converter ever supply 55 amps for battery charging?
Thank you.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
