Almot
Feb 28, 2017Explorer III
champdog wrote:
will one small solar panel and float charger be ok or am I better off taking cables loose seperating the parallel connection and using two different chargers, one on each battery. Looking to maintain the batteries the best way to get as much life as possible.
If there is a theft risk (with portable kit) - yes, a "small panel and float charger" will do. Or not. Depends on how small and what float charger.
I don't see how and why separating two 12V batteries and using two separate chargers would help though.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
