Almot
Mar 03, 2017Explorer III
Jpbeck1 wrote:
One note, don't trust your solar controller to give accurate readings on the battery charge. Buy a separate voltage meter with a shunt ($20 on amazon). Even quality controllers without a shunt plate on them are not accurate.
On the battery state of charge - correct, you can't trust controller.
On the battery voltage - yes you can, if this is a better make that has a dedicated voltage sense wire OR if the current is low, ex. in storage/maintenance mode.
The best voltmeter with 3.5 decimal points will be a very rough measure of charge. Could work in storage though. For eventual camping use you need a "monitor", something that counts AH hours in/out and gives you the net result.
Cheap voltmeters with 2 decimal points are a joke, inaccurate readings. Could read 12.60 when it's really 12.45, and readings change with time as the meter warms up and for other unknown reasons.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
