naturist's avatar
Aug 16, 2020
solar for your RV
So I was poking around this morning on Amazon, and I see that the parts to add solar to your RV have made doing so *really* competitive with generators, not just in long term operating costs, but in up-front installation/purchase costs.
Solar has always had a huge advantage in terms of long-term maintenance and operating costs (no gas, no oil, no spark plugs, etc.). With the added advantage of silence, blessed silence, while "running."
But consider the case of the RVer who just wants to keep his/her battery charged, and doesn't need to try to run an AC. Such a person needs only a small generator such as a 2000 watt class generator, which costs maybe $400 to $1,000 depending on what/where/when you buy. Then of course, you have to gas it up. And take precautions against it being stolen.
So I see on Amazon a 200 watt, 24 volt monocrystalline solar panel for $206 (don't panic, folks, perfect for charging your 12 volt batteries, explained below), and a 20 amp MPPT charge controller for $150 (takes up to 150 volts DC and converts it to the perfect 13-14.5 volts to charge and maintain your battery). Throw in mounting hardware, wires, etc. and you are looking at $400 for a system that will suit nearly everyone with a single (or even double) 12 volt "deep cycle" battery of the sort that comes with most trailers these days. It'll even handle the 125 AH true deep cycle AGM upgrade you really want.
Or, heck, go cheap and buy two 100 watt 12 volt polycrystalline panels from Lowes for $160, wire them in series, and now we are talking $350 for whole ball of wax.
So, boys 'n' girls, the alternative to that noisy, smelly, expensive-to-run Honda 2000 is at hand. Just sayin' . . . .
  • We have been using solar seven years now and it works great but I do keep adding to it. If you are planning to add solar to your RV plan for growth. I started with two 160 watt panels and one 30 amp MPPT controller. I with that I started with a 50 amp controller.
  • Been using solar since late summer of 1994. And haven’t been without since. In the process of putting 4 100 watt panels, multi-point controller, 2K inverter, and 4 batteries in our Class C. Though, as we do a lot of fall/winter camping ( often night temps in low single digits) .....the generator still gets a regular workout! memtb
  • Max 20 amp controller severely limits any expansion. 30 to 40 aren’t that much more money.
    Reminds me to exercise the generator. Unused for two weeks.
  • We have been using a solar suitcase for over 10 years but there are times when there is no sun and a small generator is needed for battery charging . We carry a 1000 watt Honda generator for charging and we have a inverter to power what we need that’s not 12 volt , its quiet and sips gas . We prefer the portable solar panels because you can move them around to get some sun if your rv is under the trees. We used to use two 2000 watt Honda generators In parallel for our last larger RV with supplemental solar use as well .
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,377 PostsLatest Activity: Jul 17, 2025
