bojeExplorerMar 03, 2019Solar installAre there any other options wiring from the controller to the battery? Can you go directly to the converter?
AlmotExplorer IIIMar 03, 2019You can, if solar is small and controller is PWM. Make sure it won't get cut off like Mr Wiz said.
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
