boje's avatar
boje
Solar install
Are there any other options wiring from the controller to the battery? Can you go directly to the converter?
  • you can ... BUT i prefer going directly to the battery
    your battery disconnect switch, might disconnect the converter
    if so the solar won't charge when the switch is used while in storage
    with solar wired to the converter
    also,connecting directly to the battery provides the most direct charge path and the best possible charge to the batteries
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
