scrubjaysnest
May 07, 2015Explorer
I have seen them ty-raped to a pvc frame to make them portable. The 135 watt will charge a 100AH of battery but you will need to be very conservative in your usage.
If you don't already have them change to LED lights ~80% power reduction. Wire an on/off switch in the radio power lead as ours drew several amps even when off due to refresh and the amplifiers always powered.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
