MrWizard
Aug 25, 2013Moderator
3M adhesive strips, permanent seal of bracket to rubber roof
screws thru bracket achor everything to the underlying wood/luan
keeps the rubber roof from seperating from the underlying structure
Almot wrote:
Yes, this is the list that I talked about. Some designs won't work for you, but Mr Wizard's mounting should.
http://i298.photobucket.com/albums/mm251/Mr__Wizard/IMAG0103.jpg
Doesn't have to be exactly like this. Mr Wiz probably used 2x2 aluminum angle. You can make brackets longer, so that they would attach to the roof with 2 or 3 tapping screws each, or you can make them higher, say, 4" tall, of 3x4 or 4x4 angle. Into the side of the panel the brackets are attached with 1/4" machine screw - either rivet nut in the panel frame, or just a screw and nut. Don't know what is that black stuff under the brackets, put roof sealant there anyway. If you use #10 screws in the roof, it is desirable - though not absolutely necessary - to drive them in the studs, they are usually on 16" centers though might be on 18". Or a well nut through the deck plywood, then it has to be not on the stud. Plenty of options.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 20, 2026
